BaronJ
Grumpy Old Git.
No, I reckon that's you.
No ! I see someone that is so full of himself that he is blind to the consequences !
But if it wasn't the tool that he used that you have an issue with then was it simply the practice of hand-holding tool on a metal lathe? There are plenty of videos of graving and metal spinning where they do just that and no-one suggests these videos are not appropriate. What exactly is the issue here?
Mate, you're going over the top. Its a 1" dremel saw blade held by its arbor with a pair of multigrips.
The fact that hand held vise grips were used is the danger ! A slip or a moment of inattention and they could easily be caught by the rotating chuck ! The correct thing would have been to secure the tool in the tool holder. That is what its there for.
Hi Terry,
I saw a guy loose most of the fingers on one hand whilst changing a planer blade and pulling the drive belt with the other. Not very pretty at all ! the blood stains were there for quite a while.
I once saw a lathe operator drop a spanner whilst the lathe was running. It landed on the rotating chuck and luckily it missed his face and hit his shoulder.
Unfortunately Jim can't see that ! I shall no longer bother visiting his web site.
The cavalier attitude that some have here ........
TerryD
I'm also struggling to see what people are getting so worked up about here.
I'm also struggling to see what people are getting so worked up about here. The 'cutter' was being held in a pair of multigrips (which I often trust enough to do various jobs involving molten metal work and have a far more reliable handle than a wooden leatherworking tool) so hands were nowhere near the spinning chuck, which is the biggest hazard in my opinion. Plus, the 'cutter' itself was a very low weight blade and not spinning at terribly high RPM, so it had little rotational momentum. If he had let the thing go while in contact with the part, it would (in my estimation) been kicked away from the workpiece and very quickly stopped rotating. If it had somehow contacted skin before it stopped it contained so little energy that it was unlikely to do any damage. As long as he was wearing eye protection I don't think there was much risk.
Joe Pie has a video on filing in the lathe and has some very interesting demos of the file touching the chuck and (usually) being ejected rather than graven though I love most of Joe's videos, I don't like his practice of filing with his left arm over the rotating chuck.
Defending the way that [the Dremel saw blade] was used, and pretending that it's acceptable to promote that approach as a reasonable and safe way to use the tool, is patently insane.
