JimDobson
- Sep 11, 2013
- 290
- 271
Thank god some of you guys weren't at Kitty Hawk in 1903. I wouldn't have a job if you were.
Best quote award.
Great comment, I nearly made reference to the very same moment.Thank god some of you guys weren't at Kitty Hawk in 1903. I wouldn't have a job if you were.
Absolutely the 'Hitler point' is a hard limit! Although I'm hoping we're respectful enough that it won't come to that...I read a study once about how discussions like this degrade to personal attacks until someone is said to be like Hitler and then the moderators end it.
If the tool slips off but stays secure in the multigrips which he is holding, there's no way for the blade to get to his fingers, and if it slips off it is no longer driven so won't have enough momentum to cause much of an injury. If the blade pivots in the multigrips, as we both suspect is possible, the blade could still be driven and may come in to contact with his finger. However, it will also come into contact with the side of the multigrips and this will a) stop it going deeper into his finger and b) stop the blade quickly as he lets go of the whole thing. There'd possibly be an injury but it's likely to be slight. Honestly, I end up with a 'gash' that needs patching at least every couple of weeks, either from bumping a milling cutter, sliding my finger along something I shouldn't or just bashing into something hard. If I don't have to stop working for more than a few minutes then I don't consider it a bad enough injury to worry about.
I made this with a stippling tool held with grips and lathe spinning really fast!
Up to Chernobyl comparisons now.....can't wait to see what's next.
Whatever happened to 'Common sense' ?
Unfortunately it is not very common these days.
The Emerald Isle
Jim. This has been the most amusing thing on here for as long as I have been a member. I know a lot of people have gone over the top with their comments. I really hope that you are not offended.
Kind regards. Steve. X
... a short term thread gang
I was a pilot & logistician in the US Army and once a maintenance tech. Long story . . . Whenever I heard someone say "it'll be ok" I knew with 100% surety they weren't planning on being there when the fecal matter started spraying. Once turned down an aircraft when the mechanic, who had probably been doing it a long time, retorqued a bolt in the rotor head assembly without writing it up or getting a tech inspector to sign it off. Didn't argue with him. But the Main. officer was royally hacked off that I spoiled his time-to-maintenance flow demanding another aircraft. Until I returned. Then he sheepishly showed me a steel shaft 2/3 gone eaten away by an aluminum crank arm. A ticking time bomb if ever I saw one. Yea "It'll be OK."Yes, point taken, but many died before Kittyhawk - Wright Bros weren't working in a vacuum but on the shoulders of their predecessors - and many have died since. Hope it wasn't one of your components or systems that was at fault in any of those situations unlike the Boeing cobbled up software - "it'll be ok".
There is a whiff of Lord Of The Flies in this thread.
