- Jul 8, 2009
- 691
- 201
Good news, my real-live 24V power supply should be here Wednesday. That means I don't have to try temporarily cobbling in the other 24V power supply, Health & Safety will be SO pleased. My fused terminals were just delivered today, so maybe I can actually start wiring the panel tonight. I DO have to pick up some wire labels though. As a controls engineer, unmarked wires just make my skin crawl.
I got the motor bracket designed, printed, and installed over the weekend, but it's a different color than the rest of the airlock parts. I can live with that because I was running out of that color filament. I didn't think I had used that much of it, but then I remembered that particular color only comes in 0.75Kg spools.
It was probably a good thing I ran out. When I tried fitting the motor to the partially printed bracket, it DIDN'T fit. It was late Friday night when I designed the bracket, and SOMEBODY got the orientation of the shaft side of the 3D model 90° out of sync with the motor side. The gearmotor is not QUITE square, and the output shaft is not QUITE centered on the face, but it's close. And the mounting studs are on 60mm centers one way, and 65mm centers the other. I was using the motor side as my reference for all my measurements, and when I plopped it down on the model 90° from where it actually was and didn't catch it...
Anywho, I fixed that problem, measured the 3D model's dimensions, compared them to the real deal and when they matched - I said all is well with the world and printed the stupid thing. Several hours later as I was carrying the bracket down to the basement to install I remember thinking - I am REALLY gonna be pissed if this doesn't fit. Fortunately it did fit, it even looks like I'll have enough slack to be able to easily install the belt - Prior Planning and all that alliterative crap.
Over the weekend I also got the last of the grounding wires installed on the dust collector ducting. The entire cyclone system is now electrically connected to the house ground. That should prevent any static build-up in the system while it's in operation.
That light up ahead in this tunnel is DEFINITELY getting brighter.
Don
Don
