ajoeiam:
In answer to your questions:
1) All the ducting is vertical through the slide. This keeps the slides in a horizontal position and also means that some type of a lock to hold the slide in position is not required - usually.
2) With luck, the gates will NOT have to be removed. (But they CAN be removed if required.)
Progress update - IT'S ALIVE!!!!
I got all 3 of the 4" blast gates made, and installed, over the weekend. This crappy, slightly shaky photo is a shot of the radial arm saw in it's new, and hopefully more or less permanent home. More importantly, it also shows two out of the three 4" blast gates. One blast gate will be for the radial arm saw, and the other will be for a removable connection that will be shared by the table saw, and an as yet to be completed sanding/grinding station.
Both ends of the slide on the blast gate are open, and the blast gate slides are long enough that when fully closed they protrude about 1/4". (That's about 6mm for you poor Imperially challanged folk on the other side of the pond.) This will push any schmootz that accumulates in the slot for the slide out the other end, and TAA-DAA they're self-cleaning. The top of the blast gate is made up out of 6mm plywood, with a 3D printed ring that is glued and screwed to the plywood. It's attached to the 4" duct by #6 sheeet metal screws and the joint is then sealed with the aluminum tape you see in the picture. The bottom of the blast gate is a mirror image of the top, that's the 3D printed red ring that you see in the picture. A pair of 3mm plywood spacers are glued to the blast gate bottom only, and are the guides/spacers for the slide. The slides themselves are made out of 2mm acrylic. (It said it was 0.080", but they're not fooling me!) The top and the bottom of the blast gates are bolted together with 6-32 machine screws, washers, and Nylock nuts. That way, if I ever DO need to clean the blast gate, I can drop the bottom half of the gate while the top half remains firmly attached to the duct - Ezee-Peezee.
Laying on top of the radial arm saw's table are several Plano storage containers. Them and several of their distant cousins made by other companies will old the various, screws, nails, bolts, and other assorted Bits and Bob that I have accumulated over the years. I'm building a rack to hold these containers in a somewhat organized fashion. Whille I was cutting some of the parts for this rack, and blowing sawdust all over the shop as usual, I realized that I have a MOSTLY functional dust collection system now. It's not DONE, but it could be used - NOW. That led to this little bit of Redneck Injunearring.
While the 4" blast gates are built and installed, the 3" blast gates are still just a gleam in someone's eye. BUT.... A little blue painter's tape to cover the unused holes, a shop vac hose shoved in the remaining hole, and a rag to stop up the majority of the remaining leak and... Wait for it!
VIOLA, you've got a dust collection connection to the table saw. Oh sure, the blade still throws some dust around, but for now this gets the majority of the schmootz off the floor and into the dust collector.
See, I TOLD you it works. This was the result of turning the airlock's hand crank 5-10 revs to empty the cyclone after I was done with the saw. Just the sawdust, ignore the other crap in the bottom of the bin.
The system still has a LONNNNGGG way to go before it is complete:
1) Build and install the 3" blast gates
2) Install the permanent connections to the drill press, bandsaw, radial arm saw, yadda-yadda-yadda
3) Imagineer the final filter for the dust collector blower
4) Build and install the automatic controls for the dust collector airlock
But... The system is usable now, and I'm getting close enough to the end of the tunnel that I'm PRETTY sure the light isn't just another train.
Don
