Hi Ian:
In Most system with the two dimensions at the limit would double the tolerance on the 80 mm dim. That would be the case if the
two limits (1) the bar long by 0.1 mm and the 20mm dim. short by 0.1 mm for a dimension of 80.2 mm and (2) the bar short by 0.1 mm
and the 20mm dim. long by 0.1 for a dimension of 79.8 mm. Few people would catch the difference because they would just check the
given dimension but a CMM would show it.
Also, just to show you that CAD work can be in error if the machine is not set to high number of places,here is a story told to me by a
toolmaker I know who became a checker because he was Good at his work. When he was checking a large diameter,around 5 ft., indexing
plate that had about 25 to 30 station on it he found one station at the final position was off location. He was doing the calculation to eight
places to find the error on the CAD print. When he went to the CAD Tool Designer, he had set the computer software to only six places not
thinking about the small error adding up that many times.
By the way did you laugh also, about the countersink dimension? 90% of the time in the shop they just drop a screw in the first hole to
be sure it is deep enough.
Stuck at home in Mich. USA
Bill Thomas
