Well, this will be the last update for this build log. I made the nuts for the bearings caps today, and consider the engine "Built". I have a little touch up to do to the paint to fix some boo-boos that happened during the last assembly stages and a little cleaning to do. Once that is done I'll take some nice photos and a video and post them in the completed engines section.
This has been an amazing experience. Building the engine itself was fun, and logging my progress here has been more rewarding than I ever expected. If you have never done a build log, I highly recommend it. This log has taken more time than I expected, and it isn't nearly as complete in terms of documentation as I had hoped for. However, I'd do it again in a heartbeat.
A while back, I promised to share anything that I would do differently now that the engine is done. There are really only three major things I would change, and they relate to the order of operations on some of the castings.
First: I would make the first operation on the frame (after I had it mounted to the reference plate) to machine the main bearings. It would be much easier to locate all of the other components by indexing off a piece of 3/8" rod stuck through the bearings than it was to figure out how to locate the bearings after I had machined everything else. I suspect this is true for most engines of this configuration, but I had to learn that lesson somewhere...
Second: I would reference all of the steam chest operations from the center of the valve rod packing gland. It takes a pretty heavy cut to get the steam chest walls down to where the valve rod will enter near the center of the gland, and I missed by quite a bit.
Third: I would pay more attention to the length of the cylinder casting before taking the first cuts. I chucked the cylinder up in the lathe without measuring the length of the casting. Since the drawings call for a cleanup pass, that is all I did on the first end. However I really needed to take off more like 0.100". As a result, I could not machine enough off the outboard end to make the cylinder the correct length.
Some may question why I left the original kit cap-screws in place on the con-rod and the eccentric. I had intended to do the stud/nut thing there, but when I tried it I didn't like the look of the brass nut against the bronze. It looked OK against the cross head slides, but not with the rod. Maybe some day I'll make some steel bolts to put in those locations. Then again, maybe I won't
Thanks again to all of you who encouraged me along the way. It really does help a lot when people post little comments along the way. I am more than a little sad that so many of the folks who were following along decided to leave the forum over the last few weeks. It is selfish of me to want them to see this engine completed, but I do hope some of them are still watching in silence.
Here is a shot of the bearing caps with the new nuts. You can see several of the chips in the paint that I need to touch up:
Here is a teaser shot of the whole engine:
