I spent some time this weekend on the base for this engine. I grew up in a wood shop, but I haven't done any serious woodworking for a few years. I was surprised how rusty I had become. There are lots of little mistakes, but let's call them "Charm".
First I ripped up some 1" wide strips of maple and cherry and glued them up to make alternating stripes:
Then I cut more 1" strips at 90 degrees to the originals. If you flip every other strip 180 degrees you get a checkerboard pattern. Here it is in the clamps for the night:
It isn't an efficient use of material, but I really wanted the checkerboard pattern to run at an angle, so I cut the appropriate piece out at 45 degrees. Then I wrapped it with an 1/8" strip of maple that had been dyed with red aniline dye. (To go with the engine) The I wrapped another 1/8" strip of plain maple around that. Finally I built a frame from cherry to hold the checkerboard.
Here are some of the pieces before assembly:
A quick pass with a round-over bit on the router table and I was about done. I still need to cut and line the flywheel pit so I can't set the engine in place yet, but this will give you an idea. One interesting trait of cherry is that it will turn much darker with time and give a nice contrast with the maple.
