So next I made the liner. This needs a 1" hole bored in it that is 3.2" long. I started by putting some cast iron in the lathe and drilling it with a 7/8" drill. Note the use of the lathe carrier to eliminate the chance of the drill spinning in the Morse taper
Then I bored the liner out to about 50 thou undersize using a carriage stop to get the depth right
The outside diameter of the liner was made to about 2.5 thou bigger than the housing inside diameter.
![IMG_0650.jpg](https://proxy.imagearchive.com/90b/90b0ffb473400c310c53db3f98e70cd6.jpg)
![IMG_0652.jpg](https://proxy.imagearchive.com/e18/e1823fc455bc9298aef819859d39a057.jpg)
![IMG_0651.jpg](https://proxy.imagearchive.com/4ad/4ad4059af1b9052a08978477a26d31bc.jpg)
