I may take you up on your offer of sending but I will check your supplier first, I been trying to find a cheaper source for the bevel gears as they are very expensive, I will get back to you, did you get your new castings yet?Hi Dave
I bought a 1 foot length from the US when I bought the bevel gears for the distributor. It is true that you technically only need about an inch of it if all goes well, but I used nearly 2 inches trying various things and then there is also some slight damage to a section where it was clamped in the jaws of the chuck (probably could still be used though).
I could always post you an inch or so but Aust post is expensive to ship overseas, so for probably not much more you could get a whole foot, especially if you're also going to buy other gears at the same time. I found SDP-SI to be the cheapest supplier and they had everything I needed in one order. Plus, they're completely online, freight is calculated automatically and everything.
Anyhow, if you need me to I can find out a shipping cost to Thailand and send you some gear stocl. Let me know if you need it.
Please take a shot of the gears in mesh.
Here you go Gus - better late than never (I nearly forgot:hDe. The punch marks are for 'timing'. I figured I ran them in in this particular configuration so they might as well stay in the same config.
Nice work Cogsy, I might tackle the water pump next, as I am not happy with my crankshaft and am waiting for new bar stock to arrive from the UK, I would like to take you up on your offer, if you could send me enough gear stock for the two gears that would be great, please let me know what the cost is so I can reimburse you, is PayPal OK?
Postage isn't all that bad depending on the size of the parcel it will go in (thickness not weight). Somewhere between $2.50 and $10.00 so if you need it then it's definitely do-able.
hi Cogsy.No worries Dave. I'll suss it out and PM you.hi Cogsy.
The crankshaft is built u from parts, so I'm using drill rod for the journals and main shaft, I bought some steel bar stock locally for the webs not sure what it is but it is very hard, anyways I messed up the alignment of the holes so I going to make new webs once the new bar stock from the UK arrives, I bought free machining steel for the new webs, I will post some pics soon.
What steel are you making the crank out of? I used 1144 stressproof that I ordered off Amazon and it cuts beautifully. I just used some 12L14 for the first time and am hard pressed to tell the difference in machinability, except the 1144 makes smaller chips (almost like cast iron). If you can get 1144 I heartily recommend it.
Please post when the multi-throw crankshaft is WIP and when done.
