Here is what I've gathered so far (I think):
Cylinder numbering is (left to right and left to right) 1,2 and 3,4 the two pairs sharing two crank journals 180 opposed, where the firing order is 1-3-2-4.
#1 fires first (I'll assume that to be 0 degrees), then #3 at 180, #2 at 270, then #4 180 degrees later, which is 450 degrees, then 90 degrees later, back to #1, which is a total of 540 degrees, which falls short of two crank rotations, which is 720 degrees.
If all of this is correct, then I am missing something....
I would have figured that everything is evenly divided by 180 degrees, with 720/4 = 180. But then again, I'm certain that #1 and #4 don't fire simultaneously as would be the case if there was a spark at every 180 degrees. Knowing this then, means that the valve timing is uneven throughout 2 complete crank rotations.
But then of course I'm not even sure if I should be working with two rotations of the crank or one.
So I'm stumped. And from what I could tell there is little discussion in this thread that has been able to definitively solve the mystery. Can anybody offer up some explanation?
