Hi everyone,
I had a pretty good weekend in the shop and was able to make good progress on the Pacific main bearings.
I spent most for Saturday prepping and pouring the Babbitt and Sunday doing machine work.
Starting out some Babbitt anchors were machined into the bearing caps and saddles. The caps were pretty straightforward using a 5/32” endmill the anchors were drilled about .08” deep.
For the body I modified my main cap drilling fixtures to drill the anchors using the 10-32 tap drill. By counter boring the fixture the shoulder on SHCS was used as a drill depth stop.
Here the fixture is set up on the body casting.
And the drilling in progress.
Here the four anchor pin holes are drilled and ready for the next step.
Aluminum shims (.040”
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
were cut and placed in the reliefs for the bearing caps; there is still some of the relief available to locate the main cap. These shims will create the parting line of the bearings.
Aluminum plates were cut and placed over the inside of the bearing bores. Then they were held in place with a bolt and nut used as a jack screw.
Here is the assembly ready for the Babbitt damming clay; the shims were left about .125” long so extra Babbitt could be poured to cover the shrink as it cooled.
Babbitt damming clay is applied around the bearing bores and up to the height of the shims. This will allow more Babbitt to be poured than is needed for the shrink as mentioned above.
Here is my melting setup; this nice propane stove my brother got surplus from his employer and the cast iron bottom pouring ladle was an eBay purchase.
The Babbitt is warming up to 800° F. and will char a pine stick when inserted. Also the bearing castings are preheated with a propane torch to remove any moisture.
Sorry I can’t shoot and pour at the same time. But here is one of the bearings just after pouring.
After both bearings have been poured the center plates are removed; looks pretty good.
The damming clay is removed from the outside of the bearings.
After cutting the excess Babbitt down to the iron casting the caps are removed.
And a closer shot of the body.
Now some shims are needed to be able to adjust for wear in the future. I first punched the hole and then trimmed the inside edge with sharp scissors.
Then the hole was aligned the hole in the bearing cap and the outline traced with a sharp scriber.
Then the shim is cut out using scissors.
Here is the punch that I used to punch the holes in the shim. These are a little on the pricy side but sure work nice. It also has pilots and can be used to punch shim washers.
And a nice little pile of bearing shims.
The shims are placed on the upper parting surface of the bearing caps.
With the shims installed and the caps tightened up the body is set up in the mill to drill and bore the bearings.
I used pretty much the same drill as before (no pun intended). Center drill, drill and bore to size. Again the upper bearing was opened up to .25” and then it was used to guide a long center drill for the lower bearing.
Stepping up through the drills the bore was opened up to 19/32”.
I made an adaptor to use my 3/8” solid carbide insert boring bar in the boring head. This worked well except I had to run it pretty slow to avoid chatter.
Here is the finished bore; some hand work and secondary machining operation are still needing to be done, so stay tuned.
I’m happy to report that the crankshaft does fit in the body and turns. It is a little tight and has no endplay but these are problems I can deal with; better than too loose.
Thanks for checking in.
