Now I'm stuck!!! I know what is happening, I just don't know why. When the slide valve is positioned in such a manner that it causes the cylinder to extend, everything works fine. I have lots of pressure, no problem. Now here is the strange part---When I move the slide valve over .100" (which is the full movement as per Elmers #33 engine which I copied the valve mechanism from), I know that air is routed to the other end of the cylinder. I have confirmed this by removing the end cap where the piston rod comes out of, and I get a good blast of air there. But--at the same time air is leaking past the valve into the other end of the cylinder, creating a back pressure, which keeps the piston rod from retracting. I confirmed this by putting the valve into the "retract" position and loosening off the bolts which hold the outboard end cap in place. As soon as I did that the air in that end was free to escape and the rod retracted with no problem. I have tried numerous positions of the valve rod, my parts are all built "on spec", I have lapped the valve sliding face, I have opened up the slots in the back side of the valve a bit to make sure its not binding on the nut or the valve rod, I have lapped the face of the slide plate. I'm running out of things to try. If anybody else out there has built Elmers 33 please let me know if the retract stroke worked okay. Science and logic tells me that it should. I have looked at the wear pattern on the slide plate where the valve slides on it, and it has a nice uniform shiny surface from the valve sliding on it.
