Great success with this temperamental runner, very instructive build, thanks to share.
Kudos, Gerard !
Kudos, Gerard !
Thank you for the reply. My concerns were about possible running heat and vibration loosening the bond. Obviously I won't be doing anything of the sort until I'm at final assembly and have made sure that it won't need to be disassembled again.think I glued the bottom and top element with a cylinder sleeve.
locktite yes adequate
it does not heat up much, no problem
hello
there are 2 springs, one lifts the leg, the other rests on the pawl .
View attachment 132220View attachment 132221
Yes. I added a little bit of downspring pressure on the slide valve push rod. That tends to pull on the valve eccentric a bit to hold just a little pressure against the pawl stop. That works perfectly.Looking good!!
One thing I've not been able to figure out is the ratchet pawl when unlatched, still clicks against the gear. I'm trying to figure out how to get it to pull back just a bit further so it doesn't click. Does anyone else have that problem?
