OK, Now I understand. The link you posted looks to me like someone put together a few different sets of drawings. The ones in color are the set I used to build mine. On page 4 of that set, is the instructions to setup the valve. I copied it here:
The setting of the Slide Valve is similar to timing the valves in a modern day engine. The valve must be set to allow fuel into the engine at the right time, trigger the ignition to fire the engine, and then allow for release of the exhaust gases. The engine should be fully assembled except for the Slide Valve and the valve cover. Lift the rack high enough to clear the levers so the pawl will unlatch from the Ratchet Wheel. This will allow the FlyWheel and the shafts to spin freely. The high point of the Slide Valve Eccentric should be in the horizontal position with the high point toward the rack. Hold the FlyWheel to prevent the rack from going down and the shafts from turning. Screw the Yoke with Slide Valve attached up or down on the Valve Rod so the exhaust hole in the Slide Valve and the Port Face are aligned. This may take a little fiddling and screwing the Valve Rod up or down in the Eccentric Valve Strap to have proper adjustment at the Yoke end of the Valve Rod. Now you can install the Valve Cover, Springs, and nuts. Tighten the nuts only enough to apply light pressure on the Slide Valve. Apply only enough pressure to prevent the Slide Valve from leaving the the Port Face when the engine is running.
