Hi Ignator, I was given parts from a wrecked Chinese bike or quad, I have no idea why it was wrecked but guess the ignition failed. In my tries I only had the wires to the CDI and coil connected, tried several coils. Power wires to the rectifier only put out 2.5 volts AC, perhaps I should connect the rectifier and a battery, but it should spark without those. No kill switch connected. As for the Onan, I have been working on the ring gear and had trouble getting my head around cutting 85 teeth with a 120 tooth rotary table, watched some Youtube videos on the subject and found that both figures can be divided by 5 ie 5 x 24 = 120 and 5 x 17 = 85 I have some indexing plates somewhere put away safe? Searched for a gear and found one 17 tooth gear, just need now to build up a gear train at 24/1.
As for the up-side-down parting tool we have been using a small Bransby lathe with no back gear and the tungsten saw blade just cuts Alloy and steel like butter, must keep the lube up to it though.
