Hi Mark, the model, second pic, runs on 7 and a quarter inch track 184mm the engine is a Victa 160cc much modified, it will run either way, has car pointless ignition with 2 wings to activate the magnetic pickup 18 degrees before TDC in either direction. In operation the engine runs backward to its original direction smoothed out by a 5kg weight flywheel. Will pull easily 2 wagons loaded with 16 adults and children.Ted,
The Fairmont in the first post you made , third pic looks exactly like the one my brother has!
cheers
Mark
Shortened Toyota engine.Yes Ignator I had too strong a spring in the valve and nowhere for the oil to go. The PCV valve on a multi cylinder engine actually works differently, it allows a small draw on the crank case at idle and a large amount at revs. My Onan powered welder began to leak at rear main oil seal but I couldn't remove the generator to replace it subsiquent owner ran it out of oil, problem I found out recently on the web if the valve clogs it will cause oil leaks. Single cylinder engine, (also opposed twin and vee twin) have a great amount of crank case volume changes due to piston displacement, I found this out when I cut down a Toyota 6 and made a single, remembered that Brigs and Straten have a valve in the breather, solved the problem. On my model I have used 2 truck compressor silencers for air cleaners and one to separate the oil blown up the breather valve, all working fine,
That looks like it took some doing to seal off all the coolant passages, especially in the cylinder head. That's an interesting project to complete.Shortened Toyota engine.
Your tin work is beautiful. Looks like this project is almost finished.Latest on the Onan opposed twin in half scale, have run it several times lately and it is starting better and will almost idle. Some more work, pictures 1-3, a few days ago this was a perfectly good 20lt drum (4 gallon) picked up on the side of the street (thrown out for annual trash pick up by council). Picture 4, making spot weldable nuts for the wire fan safety part.
Will look better with some paint. Picture 5, the back side, showing twin air filters and oil seperaater with drain back through rear bearing, coil and wires also fuel tubing, both carbies have their own fuel pumps worked by pressure variation in the valve covers.
Ted
Yes but I have a porosity problem with the sump casting, it leaks oil when not in use, not very much but it only holds a cup full. Have to take things apart and seal it with Locktite. I know that the 1920s Buicks had the same problem with the crankcase castings in alloy.Your tin work is beautiful. Looks like this project is almost finished.
I've seen single cylinder engines, like the Lauson I worked on that used a red oxide enamel paint in the interior side to seal iron casting from oil leaks.Yes but I have a porosity problem with the sump casting, it leaks oil when not in use, not very much but it only holds a cup full. Have to take things apart and seal it with Locktite. I know that the 1920s Buicks had the same problem with the crankcase castings in alloy.
Ted
I use a product we call Acetone available from hardware's, there is another product the Auto Painter's use to remove grease and finger prints off cars before painting, Wax Off or similar.I've seen single cylinder engines, like the Lauson I worked on that used a red oxide enamel paint in the interior side to seal iron casting from oil leaks.
Glyptal is a name that comes up for this paint. It's expensive at $50USD/quart.
Hopefully you can get the oil removed so you can seal it. Do you have a favorite solvent to do this? I ask, as I'm curious for any future issues I may have.
I use Acetone as well, available in every home construction supply in gallon cans. It will curdle dry paint. Worse I seem to get skin problems on my fingers when using it. And it eats nitrile and latex gloves. Oddly it's sold as fingernail polish remover.I use a product we call Acetone available from hardware's, there is another product the Auto Painter's use to remove grease and finger prints off cars before painting, Wax Off or similar.
Thanks for the questions,
Ted
