Some quick observations--The right hand cylinder with the new head gasket seems to be the dominant cylinder right now. I think the valves could still use a bit of attention in the left hand cylinder. It is firing and getting hot, but I can tell when turning the engine over by hand that the compression isn't as strong in the left side cylinder, and there don't appear to be any leaks in the left side cylinder head gasket. The "vanes" on the flywheel are blowing a good draft of air directly across the cylinders. The engine doesn't want to idle down to a slow "tick over" right now, and I think that is due to the one weak cylinder. The gas tank looks great where I have it, but I just ran the engine out of gas, and I'm afraid to fill the tank because of the hot cylinders directly below the tank. When trying to start it with my variable speed drill, the right hand cylinder was firing like crazy, but simply didn't have enough power to run the engine by itself. When the left hand cylinder kicked in, you could really hear and feel the difference. The heavy brass gear case seems to soak up all of the noise made by the timing gears. This is very exciting, as it is my first twin cylinder engine.---And I don't see any puffs of vapour coming back thru the carburetor like my clone of Malcolm Stride's Bobcat or Jaguar engine.
