And, of course...I got the 9/16 reamer today.
So off we go...time to get the cylinder out of the lathe (uh..bore, ream, and then take it out).
Need to bore to within 1/64 of the finished size before reaming.
I'm at 0.5 from the biggest drill bit I had.
Used this telescoping gauge to get to 0.546. Almost forgot...but didn't...0.01 on the cross slide is 0.02 on the diameter...whew.
At least...the caliper on the gauge said 0.546. Moved the gauge around in the hole to maximize the reading...same with caliper.
Then reamed. That's some reamer. I just know I'm going to have to shorten it some day. (As it turns out...I took the pic after reaming.)
Used the telescoping gauge again and calipered...0.564. Should be 0.5625. Cheap gauge? Swarf in the way? Poor measuring technique? Most likely the 1st and 3rd. I was pretty careful about the 2nd.
Side note: I have a cork plugging the spindle hole above the gear box to keep swarf from dropping into the gear box. Remove the cylinder, remove cork, and blow...
So now the cylinder is out. I won't drill the holes for the columns or cap, or polish the sides, until the piston is done. But I'll probably work on some other pieces first.
That's enough for tonight. Still reeling from my earlier 'fopaux'...time to medicate.
