zeeprogrammer said:
Hi Foozer,
Couple of newbie questions...
What part is the index block and what is its function?
Is that a cookie sheet on the ways? I think I've seen other people doing that. Why?
Thanks.
If I remember right, you're doing this without plans. Are you making them as you go?
I'm kinda a lazy sort, spent 20 years doing repetitive assemblies that making up little jigs to locate parts became the way. Company hated that method, called em "Shop Aids" which drove the FAA crazy. They had no way to track, anyway its a habit that I cant shake, so I'll spend whatever hours are required to make one or a hundred pieces as simple as possible.
So once I figure what I want it's just a matter of rigging up a jig to hold the part in place, do the operation and if need be drop another part in the jig and repeat the operation. Suits my nature
So the jig here is the square plate to which the 2 pieces of stock attached to become the "Index." Set the piece to be worked against the stops, clamp it down, good to go. Like using a vise stop on the mill to work a number of identical parts.
On a mill this would be a walk in the park operation. How would you do it? Me with no mill, well I don't mind the trip through the mud, keeps the Bride busy yelling at me for tracking it in
You can see in the one photo that the block to be worked isn't square, the boring edges are tapered. Be a few hours to set up a milling attachment to the lathe and square up some pieces, or change the tranny in the car, or put the new crankshaft in the bike, or change the half shaft in the other car, or cut some firewood, or . . . Ya I hooked
Cookie sheet is to catch the chips, well most of em at least. The lathe is set on 1 inch riser blocks to increase the access under it to ease cleanup.
No plan, just winging it as I go. Find it interesting to work out how to cut different features, not all turn out as desired but that's the fun (err excues not to mow the yard)
