Agreed - I would have been interested to see the effect only of cleaning the scale, without any other changes, and then compare to cleaning the scale + improving the technique. Also agreed on the benefits of starting with stick, but I wonder if TIG might be even more beneficial as a starting place (though in my limited experience, that is always the last technique learned). Really learning to see the puddle was a significant part of the learning curve for me, and with TIG, you can really watch the puddle without flux or splatter getting in the way.
One thing that I have learned from Jody's videos, that has been invaluable when dialing in MIG settings, is to do a test weld followed by a cut/polish/etch. It can be rather eye-opening to see how much - or how little - the weld actually penetrated. That has been especially helpful with the cheap import MIG welder that I have - yes, one of those import inverter machines that can do MIG, stick, and scratch-start TIG. I haven't bothered to try TIG with it, but it does both MIG and stick surprisingly well ... except for one thing. The machine I have, like so many others over the past few years, tries to eliminate the learning curve of wire speed and voltage, and instead uses a semi-sorta-integrated control with some sort of "synergic" feedback. On the one hand, this makes it even easier for a beginner to use. On the other hand, it makes it harder to know exactly what you are adjusting.
