New degreaser!
lazylathe
Hi All,
I posted a while ago about a Keller Die Filer that i had acquired.
It was pretty disgusting from sitting all oily and had hardened to an impenetrable goo!
Decided to strip and clean it so that it would look presentable.
Had all the parts sitting in Simple Green for a day and the main casting was in kerosene.
Checked then after work and the goo was still stuck! :mad:
Went to the local Canadian Tire and was looking at cleaners and found this one.
It is called "Super Clean"
Before cleaning
After cleaning in a 50/50 solution of Super Clean and water
Only a bit of scrubbing with a soft bristled plastic brush and then rinse clean under water.
Did not affect the paint at all!
Although they do not recommend any painted parts be left in the solution for long periods of time.
Length of time if mix was about 10 minutes!
Andrew
