I haven't been too active here for a while, as I have been busy with finishing off a 1964 Lotus Seven which is so much fun to drive, along with building a 160% Tomboy powered by a modified Owen Mate for the recent Oily Hands weekend at the Cowra Model Aero Club in honour of David who I miss very much.
With 14 model diesels now made and running over the last few years - 2 of which totally my design, I think the time has come to lay down another engine along the lines of the Owen Mate, the BollAero 18 the Midge and many others. I want to keep it very simple, but with a good turn of power for the weight of the engine and have penciled a few ideas over the last little while.
What I would like to do is to go through the planning process as an insight how this might be done by other budding designers and for someone to follow these ideas and rough drawings up with a CAD plan. So if there is anyone out there that would like to put these ideas into this format please let me know. I want the end result to be freely available to those that would like to build it, maybe HMEM might have a suggestion in this regard.
The initial idea is for front induction, bulkhead mount, around square bore/stroke, not too tall, conservative timing and ball bearing suspended shaft. To this end I have settled on a 14.6mm bore x 14.6mm stroke giving a capacity of 2.44 cc Initial drawings show a 13mm piston length and timing of 107 deg inlet and 122 deg exhaust. The initial drawing is working out timing etc and is to scale 2:1 it is attached along with a couple of photos of the engines built so far. Once the bore / stroke / piston length / port placement thereby read timing is decided then the bones of the engine can be designed around it. That will be the next phase.
Re the images, the first one is this latest design in progress drawing, next is a .5cc engine with longish stroke but good power only finished a few weeks ago after about a year of hap-hazard work, the next is a 1.6cc side/piston port design which gives reasonable power, Next is of a batch of others and the final one is of all the engines with names to them.
This proces may take a little while, but I think it should be a bit of fun and hopefully inspires some others to have a go at designing an engine, which is very rewarding.
Ed
Ed
