Thank you guys, for the nice comments. Things generally always get a little crazy for me at the end of a build.This one scared me a little, because until I revisited the cam timing, I was beginning to think perhaps I had built an engine that no-one else has ever built successfully, and that there was some basic flaw in the design that I had missed. I still have not found a video of a running Jaguar engine. I find it very hard to believe that I am the first person to have built and ran and posted about this particular engine. Oh, I have made a LOT of changes, but the bore, stroke, and cams are the same as Malcolm Stride originally planned for. This has been a very fast build, even for me, and it has consumed a very large portion of the past six weeks. It starts very easily now, and runs until I shut off the switch. I find that this engine does not like changes in the throttle setting very much. It likes to run fast---(again, I think the cams are right on the ragged edge of what will work in a single cylinder engine.). In the videos the George Britnell carb clone has the throttle set wide open--and if I slow it down by closing the throttle it will slow down a very little bit, then stall out. Of course I will continue to tinker a bit with it and see if this can be improved any. I have taken a good look at Malcolm Stride's carburetor plan, and it is very similar to the carb which I have on it. It is a very pretty engine, and terrifically small considering the bore. I thought that I would like to have an engine with a totally enclosed crankcase, but I'm rethinking that now. There is no good, quick way to check the engine oil level, and that oil level is critical to the big end of the connecting rod, which has no bearing on it.---And the big end of the con rod is not accessible to squirt a few drops of oil on like I can with my open crankcase engines. My machining skills continue to improve, as do my trouble-shooting abilities (which are a major necessity when trying to get a new engine started and running.) It's been fun, but I'm glad its over now for a while. I will finish off the drawings and post a download link later this week. Thank you so much to all who followed the thread and those who took time to comment.---Brian Rupnow
