Hi all, i managed to get bit of shed time mixed in with the Easter festivities and had a crack at the cylinder heads. They turned out OK although I made a mistake in locating the screw hole on one of them (plus that one has a dodgy fin) so reckon that 3rd engine will be for fitting to a plane or running experiments rather than something for the cabinet. The better heads have 2 variations: 1 with 6 fins per plan and one with 5 as machining those thin fins gave me the fear.
I cut the fins with a parting blade as shown below but wondering if there is a better way. Once the blade gets a bit deeper, the rolls of swarf seem to jam every now and again which, those thin fins, was only a whisker away from disaster. Thinking some sort of chip breaker on the top of the blade might help. Will research for next time. Also i think i would machine the fins while a big lump pf bar stock is in the lathe rather than on the mandrel. Although the mandrel gripped ok, this operation exerts a lot of force on the part and at times there was a bit of slip.
Advice above about the 0.2mm radius inserts and lube worked a treat. I'm really chuffed with the surface finish although may have to 'dull' if I get round to anodising.
Anyway, I think I'll tackle the back parts next including that valve arrangement once I get my head around the plans. The keen observer will note that I'm putting off the cylinder liners which requires making a bespoke slitting saw, angled work-holding in the mill and possibly square hole broaching.... can't avoid for ever
Anyway, here's the result and the build.
P
I first drilled and bored out the blanks to exact with generous additional material on the outer faces. I used a plug gauge to get to a close fit and then made a mandrel out of EN1A to the exact same size. Only problem here was that i needed to tighten the mandrel through the compression screw hole which limited me to an M4 cap head. This didn't really provide great holding force on a 17mm mandrel vs say a M6/M8 but i got away with it.
Next up thread the M5 compression screw hole. Figured I'd do this now while the outers weren't finished yet and wouldn't risk scratching anything up/breaking a tap later in the game.
Now mount on the mandrel and machine the outer and the compression screw 'dimple' to +0.5 mm
Locate on the mill using the lovely smooth surface.
Drill and countersink the mounting holes. Figured the drill would wander less and there would be less cleanup of burrs to do if I drilled the holes first before cutting the fins.I used a 3.3mm drill for M3 holes to give them some breathing space and be a bit forgiving on any slight inaccuracy due to the deep hole drilling.
Back on the mandrel and cut the 2mm radius/chamfer on the outer edge. The lengths I will go to to prevent having to learn HSS tool making
Here I use a chamfer/router bit or the exact radius and used it as a lathe cutting tool. Cheap as chips and seems to work really well.
And finally for what seemed like 10 hours cutting fins. As mentioned above, the parting blade approach wasn't optimal but I just about got away with it. If you look closely at the fins above, there were some that were a bit thinner than others. This wasn't me being a 'numpty' on measurement as I advanced the cross slide precisely using the graduated collars between each fin. I was a bit stumped as to what was going on but I observed the parting blade cutting on the side (rather than just the tip) after I had jammed on the swarf. I think either what happened was that the blade shifted in the holder after this or (more likely) the jammed swarf bent the thin fin and upon release, the blade would cut it straight again. Either way. Hair raising experience and I need a beer now.
The last operation was to put a 4-5degree taper on the head. I did this with the cross-slide once again
More to follow,
Thanks,
Patrick
