Thanx green twinThe only thing critical are the ports and the valve edges.
Nothing else matters much.
I just make that he valve lies on properly on
The valveface centered and thats it
Chris
The hole position which we have been talking of is also quite critical on this as there is not a lot of clearance in the valve so it needs to be within say +/-0.005" or 0.13mm if the valve is to have some movement. To little and the valve will be held tight to the port face and will also make the valve rod bind. Too much and it won't make contact with the port face and you will just leak steam/air
Hi charlesIn designing the valve I had to deal with the valve rod seemingly being very close to the portface. This is why the exhaust cavity is shallower in the middle of the width. Now we know different, the hole through the valve could be made larger, 8mm or even 9mm.
While a lot of stuff in the UK is genuinely metric, boards are still 8 x 4, they are just designated as 2440 x 1220.
I actually didnt drill that hohle yetHi charles
I can make the hohle bigger
That means it wouldent matter if paralell or not
The buckle have to be accurate isnt it?
Chris
Depends how far off it is. How much is the port face out of parallel to the valve spindle? Are you sure the valve spindle is vertical?That means it wouldent matter if paralell or not
I double checkDepends how far off it is. How much is the port face out of parallel to the valve spindle? Are you sure the valve spindle is vertical?
Hi charlesI double check
Chris
