Mystery steam engine
If the eccentrics have been made as pairs in one piece then there will be a fixed angle between the two sheaves and we can work backwards from that to find the intended valve lap (ignoring lead). If the eccentrics are separate they may have been set, and then again they may not.
Hi jason and charles
The ofsett is
If jason could match 360degrees
Over the flange then some degrees could be
Obtained easy??
Chris
    1.4 MB
    1.5 MB
    1.9 MB
    1.7 MB
    1.7 MB
That is very close to 1/4" = 6.35mm so we can assume that is what the builder was aiming for.
Depending on how far the curved expansion links can move you may or maynot get the same movement at the valve rod.
The four ctr drill holes suggest one for each eccentric, not sure if they would have been used to turn them insitue or whether they were used to clock the eccentrics in once fitted to the crankshaft.
Can you take a Sharpie or similar and mark the position of the two crank pins on the flange, it looks like one is at about 4 o'clock and the other at 8 o'clock
From the latest photos there is a fillet radius between an eccentric and the bit of plain shaft between the sets, suggesting that the eccentrics are made as one piece with the shaft. There should not be a problem with slackening the eccentric straps, if that will ease the shaft. Or any of the other bearings.
Hi jason yes the centerhohles are for crankshaftturning
Thats why i thought the thing with the degrees
However the crank pins for the pistons
I will send
The valves are just eccentrics i think
Bud have to do it t morrow
Chris
I will send
Chris
Ok now
Hi jason ithink i got the go
Look the crankpins are on 9 and six
And the high point of the valve eccentric
Is about 2 and may 2 30 for the 2 in the middle visible on the flange
The outer ones the high point of eccentric corresponds with the left side crank pin 6
With about 10
The other the right towards 9 crank pin
The hogh point of eccentric points at 5
Visible on flange
The big cylinder is right
The small is left
I hope i explain understanable?
Check it out
    2.5 MB
    2.9 MB
    2.2 MB
    1.6 MB
    1.6 MB
    1.5 MB
    1.6 MB
We should be able to work with that, I can get the angles with CAD
That looks right. Don't have much time this morning but looking at centres on flange: 10 o'clock - HP clockwise, 2 - HP anticlock, 1 - LP clock, 5 - LP anti. If we can have the outside diameter of that flange Jason can do his technique of scaling from a photo to get a pretty accurate drawing.
It is not quite as I would expect.
I used another image that was squarer on and rotated it to match the position in post #247. Added th eposition of the two crank pins.
LP looks as I would expect with the eccentrics leading the crank by 90 + approx 120deg
But the HP seems to be only show a lead of 60deg as the crank pin is at the top, the eccentric positions seem more suited to the pin at the bottom
Though I could be completely wrong.
Jason, remember the HP valve is inside admission. You have put your dotted lines where they would be expected for an outside admission valve. Your diagram shows an average of about 29° advance (the angle beyond 90°) for the LP. Though if you compare your LP radial lines with the bolt circle, which is presumably at 60° intervals, you may have a bit of a parallax issue. What angles do you get for the HP centres as they are?
That makes sense Charles in which case an average would seem to be 55deg each way.
    115.1 KB
Hi jason
Just want to say
The two centers close together are the middle of the valve eccentric
So one is for the big and the other is for the small cylinder and the further appart ines are outside so its devided in the middle
The crank pins are on the other side
Indicated
Chris
Yes, that is how I have it
    57.7 KB
Jason, could you put a pitch circle through those centre holes and compare with the OD Chris gave in #251? This would help us to be more certain of the eccentric throws (that or throw us into confusion).
I am pretty close to having enough information to reverse engineer the valves.
