Mystery machine
Roger Taylor
Active Member
I picked up this little mechanical device at a flea market. it seems to have missing parts. The head or cover is missing from the small .5"lD cylinder visible from the top. Steam engine, 2 stage air compressor. Thanks, Roger-clueless IC guy
    1 MB
    1.1 MB
    1.2 MB
    1.7 MB
    1.1 MB
Add air thru the elbow and flick the flywheel......should run......the exhaust is open at the top & the intake passage is internal....neat engine
Runs great on 60 psi, I think this is an engineering student project from Cal Poly Univ, CA,
    829.8 KB
Have you taken it apart? It looks to me like it was made in a minimally equipped shop. As in...without a milling machine?
The cylinder body appears to have started life as a coupling nut. It would be interesting to see the piston. The valve mechanism, as well.
What is the overall size of the engine?
Craig
Craig
I am now very sure that this is a mechanical engineering project constructed at the Cal Poly U machine shop in IME 144 class. lIt matches up with online drawings although there were slight changes in several versions. i oiled all the ports and it runs beautifully on 50 psi air pressure. I do intend to disassemble it and clean it up. I tried to post it running but the file was rejected as being too long?
Videos tend to be much larger files. If you upload it to Youtube, or another similar service, you can then post a link to the video.
BTW, are these plans public domain? My model engineering club is looking for another group build project for next year.
Craig
I suspect if it takes 50psi to run, then it needs a larger flywheel, or the piston is leaking badly, or the gland at the con=rod is not right... I reckon 10psi is adequate for almost all small engines like this. But an excellent model to clean-up, study, lubricate and to learn and understand how these things work.
Well done on your find!
Craig, Have you got a copy of K.N. Harris' book: Model stationary and marine steam engines? Full of designs.
Or are you simply on the web, and don't read books? - That seems to be the modern trend among younger folk? I like the sketch of your grandfather! - He would remember real books.
Nice free plans there! I think your club will find it useful? - even educational for some?
I do read both dead-tree books AND digital documents. ;) Thanks for the pointer, Steamchick. There is a copy of the Harris book in our club's library. I'll check with our librarian.
My avatar is from an animated adult comedy series, Archer. (Sort of a spoof of James Bond movies.) It doesn't particularly look like me, which I'm OK with!
Craig
Advantage of dead tree stuff - durability. Some it it has lasted hundreds of years! - But not clever compared to the Egyptian technology - record stuff carved in stone, bury in sand in a dry place, it can last 7000 years or more! 1 up on Giggle, etc. I have lost stuff 10 years old because they change software and the files disappear off my computer! - Godd job I stored stuff on CD... but where is my CD player? - Expired!
Hah! The club librarian is going to bring the Harris book to the next meeting for me. BUT, he also had a PDF version that he emailed to me immediately! So I get BOTH the instant gratification of a digital version AND the warm fuzzies of hold-in-your hands object.
Craig
