Mystery machine
Roger Taylor
Active Member
I picked up this little mechanical device at a flea market. it seems to have missing parts. The head or cover is missing from the small .5"lD cylinder visible from the top. Steam engine, 2 stage air compressor. Thanks, Roger-clueless IC guy
    1 MB
    1.1 MB
    1.2 MB
    1.7 MB
    1.1 MB
Add air thru the elbow and flick the flywheel......should run......the exhaust is open at the top & the intake passage is internal....neat engine
Runs great on 60 psi, I think this is an engineering student project from Cal Poly Univ, CA,
    829.8 KB
Have you taken it apart? It looks to me like it was made in a minimally equipped shop. As in...without a milling machine?
The cylinder body appears to have started life as a coupling nut. It would be interesting to see the piston. The valve mechanism, as well.
What is the overall size of the engine?
Craig
Craig
I am now very sure that this is a mechanical engineering project constructed at the Cal Poly U machine shop in IME 144 class. lIt matches up with online drawings although there were slight changes in several versions. i oiled all the ports and it runs beautifully on 50 psi air pressure. I do intend to disassemble it and clean it up. I tried to post it running but the file was rejected as being too long?
Videos tend to be much larger files. If you upload it to Youtube, or another similar service, you can then post a link to the video.
BTW, are these plans public domain? My model engineering club is looking for another group build project for next year.
Craig
