Today I have almost completed the Myford leadscrew. All that is left is to drill the two holes at 90° to each other to locate the two spring roller pins.
The first task this morning was to mill the small 1/8 slot to for the gear drive pin to locate in. I got into a mental mess with including, excluding, dividing the end mill in half to measure the length of the cut. However it must be because I am finally learning that a light first cut showed me the way although there is a slight overcut on the top cut. The rest of the milling job went well and the pin fitted just right, allowing a gear to fit snugly in place (see photo).
The next job was to set up the whole leadscrew and work out the position of the joint so the length would be correct. In fact it didnt need sorting and I suppose I can thank Myford for that. Since I made the constituent parts to the same dimensions as the original, all the parts fitted as they should.
One headache less, I decided that the best way forward would be to clean the end of the leadscrew, the right hand shaft and the joint piece. I then used Delta 55 high strength retainer adhesive to hold the three pieces together and tomorrow that should help when I pin them.
I must admit I dont have a great deal of confidence when gluing metal. It doesnt seem right, although I know industry relies on adhesive in a great many situations. Its only time and experience I suspect before I gain that confidence as I have read many articles where model engineers rely on such adhesives.
The post lady then turned up with a nut for the cross slide only ordered yesterday! Many thanks Malcolm. So as soon as the other outstanding items arrive, the lathe refurbishment will be complete. I have enjoyed the rebuild far more than I ever thought.
I shall have to be very careful I dont buy another
.. (no, no
