[QUOTE="Wizard69, post: 332381, member: 14419"
So I made 1-1/4 thick risers to add to the risers supplied with the lathe. This added clearance has worked out well. Other things I’ve learned include the fact that I hate screw on chucks!!!! No easy fix for that issue. Also the compound on this lathe is a joke.
.[/QUOTE]
As we seem to have moved on from 'rusty boat anchors' to 920 lathes, I always could afford proper anchors for my ventures into the briny and the 'not so briny' The tidal River Tyne has both and a note that it was once the biggest open sewer in the World. Ah??? So the 920 or 918. I had one with with a Myford 'nose'. Myford at the time- that is the original firm would not supply me with a new saddle for my- I think that it was a Super7B.
I've been through a LOT of Myfords! So I moved ALL my Myford accessories onto the '9180'. Yes there was one!
As for the saddle on the 9180, I moved quite sensibly to putting a sub table on as the tee slot are 't'other way around' I still adopt the same idea on my Sieg C4!
As for 'rising blocks',this is quite normal. Myford still sells them but I'm quite tall being once over 6 feet.
I have a pair of steel riser blocks on the Myford Super7B but a pair of wooden ones on the ML10.
Which all brings me to another point which the pontificators who never owned a Myford ML7 or Super 7 will never have discovered.
The Myford 7 series suffer from imbalance! Uncorrected, they are prone to tipping away from the operator unless bolted down. You might get away with a 1/4 HP motor but a 1/2 or a 2/3rds HP affair are rather rickety!
More to learn and think about?
Norman
