Paolo,
It might not require you disassemble everything. I would try this first.
Give it a good pickle in acid, inside and out.
Sulphuric ( 10 parts water to 1 part acid I think) is best but Muriatic from the hardware store works just fine.
If you use muriatic, use the solution right from the bottle and don't dilute it. this is my solution of choice because its convienent and it works....everybody chime in if they have a better one
Make sure you pickle the INSIDE as well so make sure all the boiler plugs are removed.
Leave it for a good hour. Agitate it periodically.....
While it's pickling, obtain a scrupulously clean plastic bucket the proper size and fill it with distilled water.
When the boiler comes out of the pickle, don't touch it with your hands, use a clean utensil
Rinse it well in the distilled water.agitate it...but don't touch it.
Now...is your torch big enough for this job? I'm guessing a 1" diameter tip propane torch connected to a 20 pound propane tank would be JUST big enough with some fire brick surrounding the part. It takes a lot of heat to get a big piece of copper hot enough to silver solder. From what little I can see in your photo, I suspect a "cold joint"
Spend a little time building a hearth from bricks to do this in. It will help keep the heat in and make life a little easier. Just the end of the boiler your working on need be exposed...but don't contaminate your part with the hearth.
Thin your CLEAN flux some with some CLEAN denatured alcohol and paint it on heavy at the questionalble joints....if there is a gap, the alcohol will carry the flux in through capillary action.
With the boiler in the hearth, THAT YOU HAVEN"T TOUCHED! ;D, bring the heat up on the part slowly well away from the joint. Don't paint the joint itself with the torch, it will burn the flux and the flux won't do it's job.
Usually when I have a problem with a joint, it's either dirty, not enough heat, or I burned the flux.....there I admitted it !![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Move the torch around and bring it up to red....the joints should reflow nicely. A clean Stainless steel scratch rod can sometimes be useful here....
You have nothing to lose if you try this and it just might solve the problem. I rarely have much luck taking a fabrication apart after the fact........
As to what to do with the acid, it can be diluted with water and then nuetralized with baking soda.
From there, its harmless, and you can dump it down the drain
A drawing of what your soldering would be very helpful to me as I don't know what you have going on in there.
Again good members of this forum....pipe in if you see a better way forward, but that is what I would do.
