My own Engine
Paolo,
That is an excellent trick! Thanks for sharing it. :bow:
As I promist the drawing of my Globe Valve is dawnloadable!! Please let me know if I did some mistakes..This is my first attempt to convert AutoCAD drawings into PDF format.
Paolo
And now..Boiler time.!! I decided for the vertical by SandyC. I decided to make a die and punch and press the discs into shape as others did. I used Plexiglas for the punch and pressed wood for the die...
Raw material
http://The punch&die just done!!
http://i268.photobucket.com/albums/jj19/Mauro1952/SM1-Engine/DSC01568.jpg
Disc test....
...and few hours later..final results!!!
Thanks firebird for sharing your idea!!!
All major components are done...!! Just a few holes and I'll start the long soldering session...!
SandyC as you can see I had a chance to find a 28mm OD copper tube...so I'm on line with the original project!!!
First soldering session....Bad results...
The silver soldering wire didn't worked well...
Second attempt using Plumbers copper soldering wire..MUCH BETTER!!!
Second silver soldering session..Was very hard to do because the copper surface is very big and the color go away very fast...
another session is needed because I have to silver soldering inside,,, :-\
We learn all times...I received a message by SandyC :bow: :bow: :bow: plenty of suggestions...That was I did for avoiding heat dispersion and I decided to use a bigger jet nozzle on my welding station...
after that I started the second silver soldering session...that is the final result...Thanks again SandyC!!
I decided to do some replenishment on the top...not so elegant, for the moment, but well done
Nice work Paolo. I had trouble with silver soldering when I first attempted it. I was using a portable propane torch...just enough heat to get myself in trouble. I learned since that time you need a lot of heat especially on large parts. Your experience is another confirmation of that. Good luck finishing up :bow:
Phil
Thanks Phil...for supporting me..!
Paolo
I must find my 'first silver-soldering' test part. It's a very ugly thing. By the 3rd or 4th joint I was starting to get the hang of it. ;D
Experience is a platform for doing ALL in the life..!!!!! :big: :big: :big:
I'm doing mine... :big: :big: :big
Paolo,
Congratulations on your progress with the silver soldering :bow:
I admire your tenacity. (I'm working on building up the courage to start a boiler ::) ???)
Best Regards
Thanks Maryak...Please Try one....this is my second ,the first was much simple and little, I had a big support from SandyC...and I was able to overcome the initial fault...I have seen your nice engine :bow:...so I bet you have ALL knowhow for doing a boiler...
Cheers Paolo
PS: Yesterday evening I started the funnel ancillaries...when..my late..died after a lots of electrical bang :-[ :-[ :-[
After that, waiting for some spare parts, I'm doing a little clean and touch on my boiler..It seams to be OK now...
That is the result after some cleaning and a touch up with my minidrill...
The top after re-soldering and cleaning....
Funnel testing...
Just received...Raw material for burners....
I would like to take opportunity for giving my sincere MERRY CHRISTMAS AND HAPPY NEW YEAR to ALL of that magnificent site...
Merry Christmas to you too, Paolo, and a happy New Year.
Have you made any progress in the last week?
I did my first solder joint with my mothers (brand new at the time) woodburning set.
LOTS of things got hot that day! :p She was not a "happy camper".
Uhmm, whats inside the white boxes?? I gotta know!
I think they are ceramic plates not boxes!
I'm thinking an interesting burner build could be on the way?
Nice work on the boiler Paolo, Have you had chance to do any more over the holidays or are you taking the full family time?
Looking forward to the next part as usual ;D
Ralph.
Hi T70MkIII I went to my country house ...so i stopped a little doing others "hobbies".... :big:
Hi Ralph...no I wasn't able to do anything because my late was broken... :mad: :mad: :mad: I received the electronic card repaired just yesterday..BUT...I have to change the motor...It seames to be "over heated" but I was able to start the burner body and finished the funnel ancillaries,as You can see, working at low speed...
Hi Kermit the white box are ceramics plate received from an Italian factory at very low price... :big: :big: :big:
