Nerdz
- Nov 19, 2013
- 115
- 19
Hello everyone! This will be my attempt at a stirling engine. Ive been making a few wobblers here and there, and I have the confidence (along with a QCTP!) now to make one.
The engine I will be building is this one:
http://www.bekkoame.ne.jp/~khirata/english/mk_l01.htm
Plans: http://www.bekkoame.ne.jp/~khirata/english/l01_k1.htm
Zip Download : http://www.bekkoame.ne.jp/~khirata/zip/l01gife.zip
Now, its in metric, which doesnt present much of a issue. The only key components are the cylinder and piston, which is fine, however, I couldnt locate the required 13mm test tube. I did, but the 10mm doesnt fit inside of the 13mm easily, So a change is required. I did a lot of research and found graphite inside a test tube will do. The ID is only Slightly bigger in my 13mm tubes (11.20mm).
The displacer will remain the same. I did notice that the ID of the heater closely matches the ID of the 13mm tube, so I will use a test tube as the heater (Ive seen others do this-Including Jan Ridders). The only issue I can see is that the displacer seems to "slide" against of the cylinder covers, and It has to be a tight fit. Having Glass Sliding against Aluminum doesnt seem like a good idea.
I may make the displacer out of graphite, or have a peice of graphite slide over the displacer and act as bushing.
Any way. Enough chitter chatter. I will be working on this as I can. I have a huge project at work and Then theres me trying to get healthy. But I need a hobby inbetween
I worked on one of the cylinder covers and a "jacking" cover to hold the test tube in place. I dont have mill yet so it was tricky making 4 holes. Once I had them in, I slide the test tube in with "blank" over it, and marked them out. It came out pretty accurate. The Cover needs to be cleaned up. I got the strange idea that if I put painters tape on one end it wouldnt be marked up as much from the jaws.
