I should guess that Viton is adequate, the o-rings should be at the temperature of the "Cold" end of the heat exchanger. Maybe less than 200deg.C? But you could use silicon - good for >300deg.C?
I did very similar things with early analysis programs. The first fluid dynamics could take all week end to run then you had to sort out data on pages of printer paper. The dual processor and more memory helped but then compressible fluids came and it was back to setting up the event to run Friday as we were leaving the office . Make sure there was a full box of print paper, new ink cartridge push “ return” and go home for the weekend. Today I’ve forgotten how to even set up the events. I’d have to dig out some notes and books I think . I don’t miss that part. I did get pretty advanced info for the era and computers my current lap top has a rediculous amount of processing power the dumb games slow it down however. Getting rid of them as I can. I just have been away too long from the guts of the computer. My under the desk computer works pretty well. I don’t have a dedicated analysis program now just what ever I can squeeze out of the cad program. I need practice otherwise I have to dig through Roarks and use the computer calculator . Prehistoric times. Again LOLThanks Ted. I wasn't sure if there was supposed to be any lead or trail due to dynamics of hot and cold gases, and the relative pressures pumping gas through interconnecting passages? Perhaps I need to study a design in more detail and see what some numerical modelling analysis of the actual chamber sizes and passage sizes can tell me? As there are no valves, the modelling should be relatively easy to do on an Excel spreadsheet I think?
Back in the early 1980s, before powerful PCs were invented, I had to use a custom written software model on the Company finance mainframe computer to model up to 9 interconnected chambers, and a 7 mass-elastic model, to understand how to tune a piece of equipment. I could have 3 runs of the computer at up to 15mins run-time per model, overnight. Seriously crude empirical adjustments required to get the model to give "real" results. Each day I would manually graph the motions of parts, from the printout (all numbers), and tweak the 3 variants to get a "better" run the following night. Eventually, the "Doctor of Maths" inverted the program so I could put in the "final result" and the software he wrote could iterate to a set of dimensions that was within 10% of the real result. I then eliminated 5% with various "fudge factors" (constants developed from the difference between the model and reality) and fine tuned from this point to Quadruple the lifetime of the equipment, and increase performance by over 25%... We had to measure deflection of the equipment under various static loads (Hydraulic jack, air pressure on the piston and dial gauges all over) to determine the stiffness of sub-assemblies. The conclusion led to a 2-phase motion at one end to get the maximum performance at the other end of the equipment. (exchanging Stored energy for Kinetic energy and back again, with some parts doing 120g acceleration, when 7 mechanical spring connections were tuned to a model comprising up to 9 gas chambers and passages). The whole development took over 6 months for the project, but the result set a new standard for the competition to "chase".
So I wonder what can be done with a "simple" Sterling engine? (3 chambers and 3 interconnections?).
All I need are plans of a model (Thanks Ken 1 for the plans attached to this), some clues of temperatures of the hot and cold chambers, bore and stroke, etc...!
I see a small mental project to drive me bonkers!
Than
, I personally can't figure out why my bought model kit has never run....
Simply ....displacer only function is to move air from hot to cold and vice versa .. But I think I must have wrongly interpreted the use/design of the displacer.
Why not ?The wire wool packing was something that doesn't fit with running of other Stirling engines
And more thermal inertia means the process is slower, less pressure fluctuation and therefore less power....?
