Steamchick, you might like to hear about my further problems and (accidental) improvements.
Although I got it running it was not as it should be - it turns out it had been dropped and was misaligned.
Anyway I resoldered the displacer but it did not run as it should and I ended up overheating it and suffering the same failure - so I added a couple of screws but this made things worse.
So I made a solid Aluminium displacer and it refused to run - I noticed a distinct "moaning" from the engine which appeared to be the displacer shaft running in its cast iron bush.
Ah-Ha - is doesn't like the mass cantilevered over the bearing - so I figured lets make a lighter piston that does not require soldering so I designed a lightweight crimped and spun closed displacer thus :-
Original weighed 6.9g - the solid Aluminium weighed 13.4g and the lightweight replacement only 3.0g :-
Various turning ops :-
First turned the outer shell parted off square - then locktite to a mandrel to machine the radiused outer end.
I turned the radius as a series of flats at 22.5° increments and then finished by file and emery. Note: I am turning in reverse - its easier to get at all the angles that way.
After crimping the end to the shaft, I spun that into the end of the displacer shell :-
I ran the ball-bearing aginst a bar and polished up and improved the corner rad with a diamond file before spinning the 0.25mm thick wall. I used a tailstock bush to align and press the assembly together during spinning.
Put the motor back together and the damn thing still didn't run.
So why this post ?
It was not a failure, the problem was misalignment all along (like I said I think it had been dropped) so once I got that sorted all was well.
Only Better.
See the video (ignore the bench clutter) :-
It will now run super slowly on a low flame.
Here's what I think: The motor needs to be absolutely free running (nothing new there) however the bending moment on the displacer rod bush generates friction - my bush is 1mm longer than Jerome's original design and that alone will help. However the radically reduced displacer mass is an even greater improvement.
Jerome's design advocates using no oil and no seals or grease in the ball bearings - even the drag from lube can stall this millwatt power engine - however I have always run mine fully lubed including the grease and seals in the ball-bearings.
But I am impressed with now being able to run it so slowly - the video is not a slow-mo and was filmed in very subdued light so you can see the flame.
Hope you get something out of this.
Regards, Ken I
