JohnCopper
- Mar 11, 2014
- 7
- 1
Hi guys, i've been digging through this forum far too long and have finally decided to build my own IC engine!
First of all, I would like to apologize for any mistakes I'll do, I'm from Germany and still learning English
My Grandfather has a workshop full of tools, including an old lathe and mill, and I'm learning how to work with them right now.
I have a vague idea of what my first engine should "look like" or more how he should overall be constructed, but there are many questions left!
I'm just gonna explain my ideas right now, if you have a suggestion of any kind, i would really appreciate it! After that I'm gonna ask a ton of question, if that's ok
So let's go:
I would like to build an one-cylinder 4-stroke IC engine with either SOHC or OHV (whatever is easier, but OHV looks better IMO) that uses a reed switch and a magnet on the flywheel to trigger a standard spark plug over an ignition coil. There should
now the questions:
1. what material for cylinder, valves, piston and so on?
2. do i need piston rings? how many?
3. is around 4% (1:25) oil in the foul enough lubrication (also for valves, how can i lubricate the open crankshaft)
4. how much displacement/compression (i would like to build an engine between 20 and 50cc = ca. 1.2 to 3 cubic inches i think)
4.1 what rpm could such an engine reach/what power can it produce?
5. are there any plans out there? (i prefer metric scales
6. ... hmm I think i forgot a few ... if I remember them, I'm gonna post again!
thanks so much for your help! I really admire all of your work!
now the questions:
