Well, got some more done today
Not much though, I finished the valve piston (on the second try
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) - I have to post a new message in the "boo boo" section :-[ )
The first photo is of drilling the port-holes into the valve cylinder. Had a nice (for me) surprise there... I located the bottom of the vice jaw on center, and being lazy, I just decided that I'd take the reading on the vertical slide to locate the center of the piece. Diameter of the piece is 12 mm, so converted to thou's & turns (my Myford IS imperial...) turned down the vertical feed. Had a quick look and things were NOT right; I expected to visually see the center drill, well, on center, and it wasn't even close! Recalculated & relocated - same thing - th_wtf1 , but interesting.
So I measured the threads on the vertical slide, and this was the surprise for me - my vertical slide is metric - not imperial, as I expected. This is nice, as I'm a "metric heretic" ;D - which makes my life a lot easier!.
Well, proceeded to do things and basically finished the cross drilling. Some slots needed milling, so, knowing I cannot use the normal chuck in the headstock for milling ( Dont ask! :hDe: previous experience :-[ ), changed to the 4-jaw chuck. Proceeded to mill the one short slot; no problems. Turned the valve around, and started on the longer slot on the other side. My 4mm cutter decided it's NOT a fun-day, and walked right out of the 4-jaw, and pierced the slot on the other side... BOO-BOO (picture 2 - part in bottom) - ruined the piece.
So I started from scratch, and eventually finished the valve. Not pretty, but will do. My lathe's got a good amount of play on the headstock bearings, so milling of any kind is risky and produce erratic results. Picture 2 (top piece) shows the "usable" valve piston with these erratic results - horrible, isn't it?. Picture 3 shows the cylinder turned 180 degrees - at least that part of milling was better...
The valve piston works like a charm in the valve-block - I expected a lot less, the way it looks...
After the valve, I started on the piston rod cross/head link. That came out OK, but guess who has got some filing in his future to finish it
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- picture 4.
Lessons learned today...
1. Double-check feed screws on machines/tables...
2. Tough one... Don't over-tighten the 4-jaw, but don't under-tighten it either - better yet, get/make a collet chuck...
3. I need a milling machine :wall: :wall:
Regards, Arnold
PS, anybody noticed me using a toolbit as a spacer? - that cheapy threading bit shred her tip the first time I tried to use her - so only good for spacing now ;D
Ohh.. 'Nother lesson: Need parallels... need money!
Pics:
