My 1st mod to new machine
V 45
I guess this is where I would post this ? I have a 7x16 lathe and the plastic handles are very sloppy. So here is my 1st attempt making anything at all with my new lathe. :) I had a really hard time using the boring bar. It just made little chips...not too sure how to adjust it. I looked over the net for help. I did drill as large a hole as possible before using the bar. Only needed to remove .012" .. it did turn out nice tho...no slop at all !!
thanks for sharing................modifying machines is fun and it makes them more functional :)
i bet if you look around on the net you will find a bunch of mods you can do to your lathe.
have fun
chuck
Very good work, that's a good way to personalize your machine and truly make it your own. :)
A good first mod to do is install a plastic shield over the apron gears to keep swarf out of the area. You probably already have some in there. Head over to www.mini-lathe.com for details.
Recently I fixed a problem with the my little lathe . The carriage hand wheel always seemed to have handle in a position that it was difficult for me to use the crosslide handle. Removed the 4" carriage hand wheel and replaces with a 3" from Honk Kong $9 including post.
Now my fat fingers have plenty of room to operate both hand-wheels a the same time.
Barry
I picked up a piece of plastic today to make the shield...already in the works. I know the handle is not much of a mod...but my 1st !! I'm certain they're will be a lot more. I really enjoy the new machine. It will be decent once I get all the slop out.
Thanx again
