Monotube Flash Boiler Design
Glad it did not zap you.
Would a fly back work?
Yes, a flyback transformer would also work,...but I don't have one of those in my spare parts box either. So, I'ld need to order a flyback and incur the same week to 10 day shipping delay. Having a short inside the coil's insulation is pretty rare,...hopefully it's a one-time occurrence for me.
If it happens again, the old school neon sign transformers work well.
Shortly after typing my last post where I mentioned how rare it is to have coil wires inside a transformer develop a short, I remembered that I never had a problem with the coils (aka transformers) on the two previous high voltage boards, which suffered shorts on the high voltage circuit boards, but the coils were undamaged. So I dug through my spare parts box, and lucky me, the coils on the dead circuit boards were the same as the shorted coil. I was able to replace the shorted bad coil with a good one from the bad circuit board, and now my ignitor board is back up and working :)
So out to the test stand to make a little steam.
Well, a little steam was all I could get. The burner flame keeps going out periodically, causing an auto re-start sequence. So, I'm sitting in front of my computer trying to understand why this is happening.
I've got some ideas,...so back to the test stand for a little investigation.
Problem found and fixed :) A tiny, nearly invisible tear developed in the silicone tube I use for the fuel line, and because the fuel is sucked into the fuel nozzle via venturi effect, and not forced into the nozzle by a fuel pump, air was being sucked into the fuel line through the tiny tear, creating air bubbles in the line which, upon reaching the fuel nozzle, cause the burner flame to go out. Sometimes, it's the littlest things that cause the biggest headaches.
Nice catch!
@Toymaker
Just a thought...
You have a burn can ECU, you know electronics and your stated goal is to move lots of air...
What about ditching the boiler and getting two of those cheap Amazon/Ebay small turbo chargers.
Rig up one turbo charger as a turbine engine with your flame can burner and then use the second turbo charger as your air blower.
You could use water injection to get more power and help keep the turbos cool.
You could also use the tesla turbine on the final turbo, to power an oil coolant/lubrication pump.
You could ditch the leaf blower this way.
This would take a lot of phase changes out of the equation which would increase efficiency.
If you reworked the final turbo to have a longer shaft, you could have it directly turning a larger blower.
@Toymaker
Just a thought...
One turbo might be enough, just take bleed air from the compressor before it goes to the combustion chamber.
@Toymaker
Just a thought...
I like you're outside-the-box thinking,....but,.... turbo chargers use radial inflow hot-section turbine wheels which are very sensitive to back pressure. If you use the exhaust from a radial inflow turbine to drive a second radial inflow turbine, the first turbine will simply stop working; jet engine designers discovered this problem in the early days of jet engine design.
Almost all RC jet engines marketed today use the design you've described (without the second turbine), and they are all fuel hogs as this simple design is not very fuel efficient.
There are people who've succeeded in building free-turbine turboshafts from turbochargers, so I think that radial flow turbines can work with another stage downstream (the one I've seen online used an axial flow power turbine- routing the exhaust back out for a second radial stage is rather inconvenient).
RC jets generally use an axial flow turbine, probably for packaging reasons (makes the back of the engine narrower).
The lousy fuel economy is because R/C turbines have poor overall pressure ratios, rarely better than 4:1 even in the largest examples. But I'd be hesitant to say that a small steam turbine could be better, especially if you have no condenser. The Brayton cycle has some significant advantages over the Rankine cycle in terms of efficiency potential (no losses to latent heat of vapourisation and generally higher temperature of the hot side, mostly).
Now if you want to be a smart Alec, you might note that the exhaust from a gas turbine is hot enough to run a steam boiler...
Hmmm, so the one you saw online used the exhaust from an axial flow turbine to power a radial in-flow turbine ?
I doubt you will be able to find a single commercial jet engine using a radial in-flow hot section turbine followed by a second hot section turbine either radial or axial.
Certainly low pressure from the single stage compressor is a contributing factor to low fuel efficiency, but it's not the only factor. Another problem comes from compressor and turbine blade operational clearances which are much the same for both RC engines and larger aircraft engines. In a large aircraft engine the required clearance between the rotating blades and the stationary wall is tiny when compared to blade length. However, that same clearance becomes a much larger percentage of overall blade length in the much smaller RC engines.
Another inefficiency suffered by small RC engines is a direct result of the limitations of metallurgy. Even in aircraft jet engines, the vast majority of air moving through the engine is used for cooling purposes and is not a part of the combustion process taking place in the burner. Even the best turbine blades used today cannot survive adiabatic flame temperatures from burning kerosene, therefor, hot combustion gases must be cooled by mixing them with air from the compressor before they impact the turbine blades. Blades used in larger aircraft engines are constructed with internal air channels which route air from the compressor through the inside of the blades and out through tiny holes on the leading edge of each blade, thereby further cooling the blades, buffering them from hot combustion gases. Finally, during the fabrication process, commercial turbine blades are subjected to near melting temperatures in a kiln for several hours and are allowed to cool in such a manor as to force the blade's metal to become a single crystal. Crystals are much more heat resistant than other metal forms and can withstand higher temperatures than castings or worked metal.
All of these additional processes allow commercial engines to operate at much higher TITs than RC engines. (TIT = Turbine Inlet Temperature), and in the jet engine world, higher TITs result in greater efficiency. At the time I stopped working in the gas turbine industry (40 years ago), I knew that both GE and Garrett were testing all-ceramic turbine blades in pursuit of higher TITs,...I don't know how successful they were.
RC engines do not use these advanced manufacturing processes or internal blade cooling designs, and therefore must run at lower TITs, resulting in lower efficiency.
I think you'll find that the advantages of higher temperatures in the Bryton cycle are more than offset by the substantially higher gas pressures found in the Rankine cycle. Compressor outlet pressure in gas turbine engines almost never exceed about 300 psi compared to 3000 psi found in many steam turbines. Higher pressure means higher mass flow through the turbine, resulting in greater power density and greater efficiency.
I have no interest in doing a math comparison between Bryton and Rankine cycles. For me, it's not a question of which one is the most efficient, but rather a question of which engine can I actually build in my DIY shop. :cool:
There are 0 bypass and very low bypass turbine engines (turbojet) in use, all that I know of are in military craft.
The term bypass refers to the air going around the engine core in a twin spool engine. GE's F404 is an example of a low bypass engine. All single spool engines are, by design, zero bypass, as all the air entering the compressor travels through the entire engine. The phrase "zero bypass" does not mean that all the air going through the engine is used in the combustion process. I've read a few online descriptions of "zero bypass" stating it means that all the air entering the engine goes through the combustion chamber, which is true, but incomplete. Yes, all the air entering the engine does go through the combustion chamber, but only a small fraction of that air is used to burn the fuel, the majority of the air is used to cool the sheet metal used to make the combustion chamber, and is also mixed with the combustion gases to cool those gases before they enter the turbine.
However, the turbines used on cruise missiles intentionally use much higher TIT, which increases engine thrust at the expense of much shorter life of the turbine blades,....but cruise missile engines are on a one-way trip, so they don't need to have long lives.
You are splitting hairs lol. Yes in a 0 bypass engine, some air is by necessity used to cool the combustor but all air flow is through the combustor.
That makes the blades all compressor blades vs fan/compressor blades.
Etherway, it still might be a great solution for you with the addition of water injection?
.... Even the best turbine blades used today cannot survive adiabatic flame temperatures from burning kerosene, therefor, hot combustion gases must be cooled by mixing them with air from the compressor before they impact the turbine blades. Blades used in larger aircraft engines are constructed with internal air channels which route air from the compressor through the inside of the blades and out through tiny holes on the leading edge of each blade, thereby further cooling the blades, buffering them from hot combustion gases. ...
Thank you Toymaker, your description recalled a visit( made during my engineering degree course some 40+ years ago to an investment casting company in the South West of England. They had a number of examples of small turbine blades which had been investment cast with several voids up the inside of the blade. The tiny holes had then been applied by spark erosion - an early introduction to some fascinating processes. At one time I had my sample blade but I think its long gone now, too many moves since then!
Thank you for suddenly bringing that memory back to me!
Simon
Some designs rout a substantial mass of air flow around the outside of the combustion chamber which both cools the chamber's metal skin and mixes with the combustion gasses to cool them before they enter the turbine.
If I understand your idea, all the injected water would be lost to the atmosphere and not recoverable, yes?
Since the end goal is to place this engine into a vehicle, all the injected water would need to be carried in a separate tank. So, maybe not a good solution.
Yes in my idea the water would be lost, are you planning on adding a condensing system to yours? I thought yours was going to let the used water escape?
Yes some engines do but to my understanding they are classified as low bypass engines not zero bypass engines.
The term bypass refers to the air from the fan section of the engine which flows around the core engine (often referred to as the gas producer) and never enters the engine's high pressure central core. High or low bypass does not refer to how much air is flowing through the combustion chamber.
Yes, my design is a closed system, with a condenser.
Yes I realized my vocabulary error as soon as I posted it, hence my pre-edited post 😋
Will you use the blower to cool them condensers?
Yes, I will place the cooling tubes along the inside walls of the blower's exhaust tube/nozzle in such a way as to least interfere with air flow & still get good cooling. The large, high velocity air flow should allow for shorter, (and lighter) condenser,...at least that's the plan. :)
Is the idea that you want pressure, flow or air velocity maximized?
You could probably have some real real fun designing a nozzle to give you what you want while cooling the steam.
