Thanks!Answered in the DIY Tesla Impulse Turbine thread.
<snip>
So the 72% isn't the same mass flow of water against "steam production back-pressure" as the mass flow of cold water issued from the pipe).
<snip>
My friend, you need a new gauge. The pressure range you want to measure should fall with the two thirds to one third of the middle of the gauge.
Measuring your back pressure with that gauge is not giving you meaningful data...
Fair enough!Sometimes, you use what you got![]()
Fair enough!
Edit: What's the availability of stuff like gauges where you are? Can you walk into a hardware store and pick one up or do you need to order it? Genuinely asking.
I am looking forward to any revised calcs. considering the estimated 40psi back pressure...
Recent tests have shown that I need a smaller feed pump; 2 LPM at 60 bar (870 psi) should work nicely. Any suggestions on where I can find one?
Thailand has numerous hardware stores, much like the big-box stores found in the US (Home Depot) and carry mostly home-use items. Stores that carry hardware for builders like me, are typically mom-&-pop stores that carry a mixed bag of items,...one store may have what I want, but I need to go to the store, in person, to find out if they actually do have what I'm looking for. Sometimes I get lucky and the store has what I need, but mostly, I end up ordering my parts online.
snip
Needle valve with a return hose, a stainless hydraulic valve.
If you also get a stainless over pressure valve you can put it and a ball valve with a low psi gauge on and have them connected to a ball valve.
Edit: can you just machine a plate to hold the bearing and swash plate arrangement and put the d
Pump motor on a belt drive jack shaft?
re-edit: many triplex pressure pumps have a bearing on the drive shaft so they can be chain or belt driven. Lacking a wobble plate, the efficiency is high, they run cooler and have a longer oil life as well as bigger oil sumps.
They can be run across a wide range of speeds.
A triplex pump is probably best for you with either one that has the capacity for side thrust allowing a direct pulley install or one that does not and instead has a jack shaft.
They are also better at pulling water from a reservoir, usually, and are far easier to maintain.
Ordering online - - - where please?
We could do the math, but I bet the longevity of whatever they stuck in there would be really subpar?Keeping the current pump and installing either a by-pass arrangement or a speed reducer (pulley or geared) would most likely work,....but it's not a very elegant solution. Another important consideration to me is keeping the weight down, and using a much smaller, lighter feed pump would be nice. Clearly, the simplest solution for me would be to find a small pump with a DC motor attached that's ready to drop in. The specs for this cordless Pressure Washer are ideal,...but can I trust the specs??
Let me know what you think.
Edit: adding a return line with a servo mounted to a three way valve would give you the option of adding a radiator. Keeping the reservoir in the pumps happy range will be a real consideration. This could give you the ability to digitally increase the pump flow, increase bypass and by doing so, cool the reservoir. And that, to me, would be elegant.
Esska-tech may have one 60 bar 6.5 lpm
This past Dec., when I was still looking for the prefect feed pump, and before I purchased the beast I'm using now, I purchased this Cordless Pressure Washer ; with a price under $30, and a claim of 60 bar and10 LPM, I had to try it. After I had a chance to test it, I found the max flow rate was actually 3 LPM and max pressure was closer to 30 bar (435 psi); well under what I was looking for at the time. Today, my needs have changed; the 3 LPM is a bit high, but acceptable, and 30 bar is close to what I need.
The same company I purchased the first cordless pressure washer from is now selling this slightly more powerful washer for just over $30. They claim 100 Bar and 4.1 LPM; if it meets half of those values it will be a good fit for my needs.
I will try this approach first![]()
