Hi Dennis. I am sorry to hear of your intake spring problems... These things are finely tuned by the original designer.... I have one on and atmospheric gas engine that I cannot get to work. My experience is that the original design must be followed exactly, as "any old spring" won't work. I have a selection I made as I didn't have exactly the design on the drawings, and that is my downfall with that model.
Good luck fixing that one!
I was unable to open the vid on timing, post #30, and the attachment on post #32 fails as well. Possibly my software? - What format are both of these?
From the post #31 vid I estimate the engine firing speed to be maybe 200~300rpm... so if it wasn't running I would start with ignition at maybe 10degrees retarded, or at TDC and work around there - chasing the "best" condition - until I found the optimum. But as you have something good (when you fix the inlet valve spring) you can just hunt in 5 degree intervals around where you are and see where the optimum timing lies. Back in the 1980s, I worked with a guy who had an engine on a dynamometer, and at various speeds and loads he was recording the actual optimum timing for ignition for max power at each engine speed from Idle upwards (in 500 rpm intervals) by rotating the contact breaker plate (actually, rotating the whole distributor) and watching the power result from the dyno, then using an oscilloscope to record the optimum timing he had found. This data went back to the "advance-retard" engineer to fine-tune the advance-retard mapping. But you have not got a dyno, just an ear!
Enjoy!
k2
