Here you go:
As a size reference, the lifters have a diameter of 12mm.
Side note: I originally designed the injection pump to couple directly to a control rod from the governor. To make this work the rod has to flex to follow the arm that extends from the pump fuel control sleeve, which is sure to create a bit of extra friction. I wonder if it might not be much more difficult to use a proper gear rack instead, might even make some aspects of the governor design easier to arrange. Any opinion?
