Did you intentionally leave the lightening holes out of the non-flywheel side bearing mount? Do you think that will push the engine into the over-weight range?
As always, very nice work.
Drat, I knew I was forgetting something haha.Did you intentionally leave the lightening holes out of the non-flywheel side bearing mount? Do you think that will push the engine into the over-weight range?
What does a knife gate look like? I've not heard that name before?A few casting observations/suggestions:
1. I have used sodium silicate mixed with sand for cores, and it works well (use the exact recommended amount of sodium silicate, and gas for 5 seconds only).
You can try baking the cores to make sure they are completely dry, and you can also bake the sand before you mix it with the binder, again to make sure you don't trap moisture in the core.
2. They recommend venting cores, and so for instance for a round core, I would use a 1/4" round wood dowel rod down the center, and when the rod is retracted, you have a hole in the core.
The hole in the core is vented out both ends into the sand mold, with vent holes extending up and out the top of the cope.
3. It sort of looks like you are overheating the aluminum melt, which is very easy with an oil burner.
Oil burners will bring 20 lbs of aluminum to pour temperature shockingly fast, such as withing 12 minutes.
4. Pour temperature should typically be around 1,350 F.
Any hotter than that and you get a lot of metal sort of soaking into the sand before it solidifies.
5. One way I have been told to judge the pour temperature, if you don't have a pyrometer, is to watch the meniscus at the crucible wall.
As soon as the meniscus goes flat, you are at perfect pouring temperature.
6. On a long thin part like that, I would probably try a knife gate, for a fast fill with low velocity.
Hope this helps.
Oil burners are great, and one never has to get a propane bottle refilled.
They will burn kerosene, diesel, waste oil, etc.
Great castings and furnace/burner !
So they are more or less shallow, wide gates.Lets take the rectangular open-bottom piece that you cast, which I guess is the engine base.
I would ram up a drag, anchor the core in the drag, carve out a U-shaped runner around where the base of the pattern will be, and have gates enter both sides of the casting, with the gates being perhaps 3/16" tall, and 2" wide.
The sprue would enter the center of the U-shaped runner.
The pattern would be completely contained in the cope, and the mold would fill upwards.
I would use a few 1/16" vent holes from the top of the cope mold out the top of the sand.
The runners would extend an inch or so beyond the gates, and I often vent the ends of the runners up and out the top of the cope mold.
You've got enough work into this part.Did the piston this evening.View attachment 148855
This all went as perfectly as could be, right up to the point where I was drilling the drain holes in the oil control ring groove and my 1mm drill snapped down inside the hole. There's no way to get it out, so I can either cast a whole new piston or use this otherwise perfect example and risk the broken drill working loose while the engine is running, in which case it would no doubt find some way to cause all kinds of havoc. I've read you can dissolve drills and taps out of aluminium parts using alum solution, has anyone tried this?
Moaning about my rotten luck aside, I'll add that the special alloy I used to cast the piston machines wonderfully, the surface finish is fantastic even when machined dry and the swarf breaks into nice little curls.
