Hi Nerd, I should check cutting speed from standard tables for the tool bits and material combinations. Also, a less pointed tool and slower transition across the metal, so cuts are finer, is the simple way to improve surface finish. And very thin oil lubrication may help - or not?
I one (industrial) job we were machining flat smooth surfaces with a "woodworking machine" @ 6000rpm. (Overhead router?), 5 in diameter fly-cutter head, carbide (?) tool for ALUMINIUM (much sharper and different angles to regular steel tools) but it was on "Pure" electrical aluminium bars. We needed ridges and grooves for the electrical low resistance joints when bolted-up, so used a smaller radius and fast feed - with a relatively fine cut and the confused coils of swarf flew off the machine (up to the guards) and had to be cleared frequently.
I guess you could flatten the surface of your cylinder head - suitable for the head gasket - with a fly-cutter in your vertical milling machine with a larger radius tool and slow feed?
But maybe I am wrong as this guide suggests otherwise?
https://waykenrm.com/blogs/fly-cutt...ze one or,suitable for heavy material removal.
Cheers!
Point Radius
Professional machinists maintain the point radius of the fly cutter tool to less than 1.5mm. This is because the smaller the point radius, the slower the feed rate, thus giving a fine finish. Thus, make you avoid large tip radiuses as they increase the tool cutting pressure, causing deflections. This eventually results in squealing, chatters, and poor finishing outcomes.Cheers!
