The problem is that bar stock in either system of measurement has reasonably large tolerances, so buying a 6mm piece of x material may yield a bar that measures anywhere from 5.5 to 6.5 mm and the same goes for imperial, a 1/4inch round bar may measure from .225 to .265 inches. Metric drill bits and reamers are just as much of a problem also, a 6mm drill bit may actually measure 5.8 to 6.2 mm,
I would be definitely changing suppliers if I were you. Want closer tolerance steel, buy cold rolled. As far as drill bits go, in over 40 years as a toolmaker I have never found a drill bit to be as far undersized or oversized as you have.
Paul.
am i being to fusy to expect to buy plans in metric?
i,m looking at my 1st build, and i know its relatively easy to convert, but to start changing a fraction to a decimal then x 25.4 is becoming a pain i can do without. ok doing 1 or 2, but they just dont convert ? or am i being stupid.. ie 1/2" = 0.5 x 25.4 = 12.7mm !!! now come on... 12.5 or 13mm i can cope with...
i have been trying to find metric plans for a simple (ish) static beam engine for ages now, without success.
any help guys for a simpleton ?
