- Aug 25, 2007
- 3,890
- 715
Locating and drilling bolt holes on a circle of a specific diameter has been a bit of a black art for me that I never mastered. So, when it came to making an adapter plate for my new 4", 3-jaw chuck I decided to do it the easy way. I turned a chuck with existing holes upside down and clamped the self centering jaws onto a center pin in my rotary table. Then I simply moved the milling table over until a screw chucked in the drill chuck exactly lined up with one of the threaded holes in the back of the chuck.
Then I removed the chuck from the rotary table and clamped the adapter plate to the rotary table, centered on the same pin used to center the chuck. Put a center drill in the mill and proceeded to spot, then drill the holes using the rotary table to index the proper position on the bolt circle.
Chuck
I did the same thing for the outer ring of holes used to bolt the larger, 4 inch chuck to the adapter plate. I know this won't teach anyone the proper way to locate holes but it worked for me.
Chuck
