nowramfg
- Apr 28, 2010
- 77
- 25
It is about time to continue with this.
The fuel pump is a very complex, for me!, piece to make. I hacked it out of a piece of brass bar, and added a piece as required. The drilling, cross drilling and ball valves were a test of my skills. I did OK, except that when assembled it did not work very well. I discovered just last night that I had made the piston shaft about .040" too short. I made a new one and it now works![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The Ti valves have been fitted, and lapped in after numerous tries!. The rockers were cut from 1/2" MS plate and hand filed to shape. The rocker shaft is a piece of 1/8" dia drill rod, drilled each end for split pins.
![Injector parts.jpg Injector parts.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/20/20232-Injector-parts.jpg)
![rocker WJ.jpg rocker WJ.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/20/20233-rocker-WJ.jpg)
![rough rocker.jpg rough rocker.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/20/20234-rough-rocker.jpg)
![top view.jpg top view.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/20/20235-top-view.jpg)
![Lister fuel pump.jpg Lister fuel pump.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/20/20236-Lister-fuel-pump.jpg)
