Very nice work, Xander.
Chuck
Chuck
Excellent work! I found this post after seeing a video about this engine in a tug-boat. If anyone wants to hear the hypnotising sound of the original, I'd recommend a watch (the dialogue is in Dutch, but that doesn't really matter - there are subtitles, anyway).
I am delighted that somebody is making a model of it.
I used a honed edge of HSS, then polish the surface with 2000 wet and dry(wet oil).How do you machine the back taper on the valves to get such a nice surface? My valves after turning look good but under a hand lens have visible grooves that seem to make for poor sealing sometimes.
Freshly ground and stoned HSS toolbit 60 degree point, 4th from the left. Very slow feed rate, i.e. much smaller than 1/5 of the nose radius per revolution.How do you machine the back taper on the valves to get such a nice surface? My valves after turning look good but under a hand lens have visible grooves that seem to make for poor sealing sometimes.
How about the tool pressure since it is really a form tool rather than a single-point turning tool? Does it have the tendency to chatter and/or bend the valve stem?Earlier I asked about getting a real nice finish on the valves. Got some really good input.
While the valve was in the lathe I spied a lathe tool I bought on a whim some time ago. The tool is one of those Chinese Disc tools, a round carbide disc insert on the end of a stalk. It cut beautifully with no grooves and a nice finish using a very light cut, a heavy cut will result in chatter. It also imparts a nice finish on straight turning. Being a disc it offers an infinite amount of cutting surfaces by rotating it.
