nowramfg
- Apr 28, 2010
- 77
- 25
It is about time to continue with this.
The fuel pump is a very complex, for me!, piece to make. I hacked it out of a piece of brass bar, and added a piece as required. The drilling, cross drilling and ball valves were a test of my skills. I did OK, except that when assembled it did not work very well. I discovered just last night that I had made the piston shaft about .040" too short. I made a new one and it now works
The Ti valves have been fitted, and lapped in after numerous tries!. The rockers were cut from 1/2" MS plate and hand filed to shape. The rocker shaft is a piece of 1/8" dia drill rod, drilled each end for split pins.
