HennieL
What is your preferred method of drilling deep holes as accurately as possible using a lathe? I have been thinking about this for many years, trying to decide the "best" way to drill a reasonably large hole (say 16mm diameter...) for a depth of (say) 10 x diameter into steel. In your opinion (for hobbyists, and not using specialised through lubricated gun drills, etc.):
I normally use the first method, but would appreciate your comments on this. Also, please feel free to comment on any other method you use, and also on drill bit types, twist rates, using a drill chuck vs using Morse tapered drills mounted directly in the tailstock, etc. etc.
Thanks for your comments
Hennie
- would it be better to drill a small diameter pilot hole (say 4mm dia.) as deep as it can go, and then only drilling once using the final size drill, or
- would it be better to use a succession of increasing sized drills (say 4mm, then 8mm, then 10mm, 12mm, 14mm and finally 16mm
Hennie
